• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Contributor
    RRufino
    API Help - Bar lenght and Other
    222 Views, 18 Replies
    10-18-2012 04:28 AM
    Hi all,
    I was trying to adapt some macros that some users gently post here on Discussion Groups.
    I already made a part of what i wanted...but this is the first time i'm trying to use macros, so i'm not being able to do the rest.
    I have already a way to have all forces on my xls file, but i want to get in the following columns Lenght(m) | Section | Rect_BF | Rect_HT | Rect_EP | Bar Name | Deflection (mm)
    How can i do this? Can you help me?
    Thanks, please see attachement
    Please use plain text.
    Product Support
    Re: API Help - Bar lenght and Other
    10-18-2012 04:39 AM in reply to: RRufino
    Example code:
    The sectional data \ interface \ access depends of section type: from database or user or tappered or complex ....
    What sections do you have?
    Dim RobApp As New RobotApplication
    Dim Bar As IRobotBar
    Dim Sel As IRobotSelection
    Dim Sec As RobotBarSection
    Dim BarCol As RobotBarCollection
    Dim sectData As IRobotBarSectionData
    Set Sel = RobApp.Project.Structure.Selections.Get(I_OT_BAR)
    Set BarCol = RobApp.Project.Structure.Bars.GetMany(Sel)
    For i = 1 To BarCol.Count
        Set Bar = BarCol.Get(i)
        Set sectLab = Bar.GetLabel(I_LT_BAR_SECTION)
        Set sectData = sectLab.Data
        Set Sec = Bar.GetLabel(I_LT_BAR_SECTION)
        Cells((7 + i), 1) = Bar.Number
        Cells((7 + i), 2) = Bar.Length
        Cells((7 + i), 3) = Sec.Name
        Cells((7 + i), 4) = sectData.GetValue(I_BSDV_AX) ' A of section
        Cells((7 + i), 5) = sectData.GetValue(I_BSDV_D) ' h of section
    Next i
    Exit Sub
    Rafal Gaweda
    Product Support
    Active Contributor
    RRufino
    10-18-2012 04:57 AM in reply to: RG_Adsk
    I have regular Rc Beams and Rc Columns.
    I tried to copy that code to "my" macros but it simply not work...where should i paste that?
    Thanks in advance
    Product Support
    10-18-2012 05:01 AM in reply to: RRufino
    OK , I will show you.
    It was example for steel sections - copy it to separate xls file
    Rafal Gaweda
    Product Support
    Active Contributor
    RRufino
    10-18-2012 05:48 AM in reply to: RG_Adsk
    Thanks Rafal, if you don't mind please check the attachement on my first post.
    Product Support
    10-19-2012 01:25 AM in reply to: RRufino
    Take a look at attached xls
    Rafal Gaweda
    Product Support
    Active Contributor
    RRufino
    10-19-2012 02:22 AM in reply to: RRufino
    Dear Rafal, i don't know how to thank you!
    Thank you so much!
    Greetings from Portugal!
    1000 kudos for you!
    10-19-2012 02:47 AM in reply to: RRufino
    Hi Rafal,
    I'm seeing that this macro is for 2 or more points in a bar.
    What should i do to extract data only for 1 point?
    For example:
    I want data (forces, section propreties, etc...) for the point x=0 of the bar.
    Thanks in advance,
    Cheers!
    Distinguished Contributor
    athurD
    10-19-2012 03:39 AM in reply to: FilRib
    hi.
    File excel erro ???????
    10-19-2012 03:42 AM in reply to: athurD
    Where is the error?
