Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
API Help - Bar lenght and Other
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi all,
I was trying to adapt some macros that some users gently post here on Discussion Groups.
I already made a part of what i wanted...but this is the first time i'm trying to use macros, so i'm not being able to do the rest.
I have already a way to have all forces on my xls file, but i want to get in the following columns Lenght(m) | Section | Rect_BF | Rect_HT | Rect_EP | Bar Name | Deflection (mm)
How can i do this? Can you help me?
Thanks, please see attachement
Re: API Help - Bar lenght and Other
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Example code:
The sectional data \ interface \ access depends of section type: from database or user or tappered or complex ....
What sections do you have?
Dim RobApp As New RobotApplication
Dim Bar As IRobotBar
Dim Sel As IRobotSelection
Dim Sec As RobotBarSection
Dim BarCol As RobotBarCollection
Dim sectData As IRobotBarSectionData
Set Sel = RobApp.Project.Structure.Selections.Get(I_OT_BAR)
Set BarCol = RobApp.Project.Structure.Bars.GetMany(Sel)
For i = 1 To BarCol.Count
Set Bar = BarCol.Get(i)
Set sectLab = Bar.GetLabel(I_LT_BAR_SECTION)
Set sectData = sectLab.Data
Set Sec = Bar.GetLabel(I_LT_BAR_SECTION)
Cells((7 + i), 1) = Bar.Number
Cells((7 + i), 2) = Bar.Length
Cells((7 + i), 3) = Sec.Name
Cells((7 + i), 4) = sectData.GetValue(I_BSDV_AX) ' A of section
Cells((7 + i), 5) = sectData.GetValue(I_BSDV_D) ' h of section
Next i
Exit Sub
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have regular Rc Beams and Rc Columns.
I tried to copy that code to "my" macros but it simply not work...where should i paste that?
Thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
OK , I will show you.
It was example for steel sections - copy it to separate xls file
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Rafal, if you don't mind please check the attachement on my first post.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Take a look at attached xls
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Dear Rafal, i don't know how to thank you!
Thank you so much!
Greetings from Portugal!
1000 kudos for you!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Rafal,
I'm seeing that this macro is for 2 or more points in a bar.
What should i do to extract data only for 1 point?
For example:
I want data (forces, section propreties, etc...) for the point x=0 of the bar.
Thanks in advance,
Cheers!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
hi.
File excel erro ???????
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Where is the error?
