3D model problems
3D model problems
3D model problems
I am working on 3D model of a steel structure. No matter how I model the releases, the program always tells me there are  instabilities type 1 2 or 3.
Would you please show me how can I model my roof truss to work only with normal forces, the X bracers on the roof too and the purlins - to be simply supported (by the nodes of the truss). All that without giving me warning for instabilities.
PS: There are some elements missing because the model is in very early stage. That my occur in other instabilities problems. I just need to understand the principle of 3D modeling in RSAP to model elements like those I asked for.
Please forgive my poor English.
Thankyouinadvanceforyourtimeshared!
http://www.4shared.com/rar/eXvDzWvq/Ramka_3D_3D.html?
Rafal.Gaweda
Autodesk Support
Autodesk Support
Bottom chord of these trusses are instable either due to excessive releases on bars or missing bracings \ stiffeners.
Example - red bars below added.
Rafal Gaweda
Thank you for your example. But is it possible to do it just with appropriate bar releases, because I don't need that many elements between the joints of my bottom chord.
To be exact my question, is there some kind of a rule for releases in 3D model like the one in 2D model - node with N number bar elements joining it, there must be N-1 releases.
I hope I explained my problem right.
Thank your for your time!
Rafal.Gaweda
Autodesk Support
Autodesk Support
It is not that simple.
It depends on released dofs, not on general number of releases in node.
Rafal Gaweda
Rafal.Gaweda
Autodesk Support
Autodesk Support
Take a look at LCS of bars and released dofs.
Maybe like that:
Rafal Gaweda
Thank you for your post, now I will try your suggestion.
Now after I try your proposition, I see everything works just fine, thank you very much! I have one type 3 instability, but despite it, all the results from my test loads are all what I expected.
