• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Structure
    Active Member
    leahmcphail
    tiling windows when one is a schedule
    187 Views, 3 Replies
    01-05-2012 07:09 AM
    I was wondering why I can't tile my windows when I have a schedule along with plans/sections open as well. If the active window is NOT a schedule, I can tile, but not if the schedule is active.
    Thanks for any input.
    Please use plain text.
    Distinguished Contributor
    Re: tiling windows when one is a schedule
    01-07-2012 10:11 AM in reply to: leahmcphail
    Schedules will tile but you need to be in a view to get it to work.  Open the schedule, then activate the view and click "window tile".  It is really handy and I use it all the time.
    Active Member
    leahmcphail
    01-09-2012 07:00 AM in reply to: leahmcphail
    It is good to know that a view has to be active for the tiling command to work.
    Thanks so much!
    Employee
    Joe.Charpentier
    02-10-2012 11:13 AM in reply to: leahmcphail
    You're probably referring to the Keyboard Shortcut "WT".
    In general, keyboard shortcuts will not work when you are in a schedule view, as most of the time you will be editing text.
    However, you can still activate the "Window Tile" command from the ribbon:
    "View" Tab>"Window" Panel>"Tile" Button (off to the right)
    Joe
