Autodesk Revit Structure
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
technology preview of Structure Generator for Revit on Autodesk Labs
- Highlight
- Email to a Friend
- Report Inappropriate Content
There is a new technology preview that 2012 users of Revit Architecture and Revit Structure users can try.
http://labs.autodesk.com/utilities/revit_structure
The technology preview that provides a connection between massing models and objects created during conceptual design and structural elements such as beams, column, walls, plates. With Project Structure Generator, structural engineers and architects, from the earliest stages, can very quickly create and visualize a physical and analytical model of a structure based on the massing model.
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
Re: technology preview of Structure Generator for Revit on Autodesk Labs
- Highlight
- Email to a Friend
Hi
Can we have some info and how to best create the masses as I keep getting the following error
Mesh elements are not found in the current selection.
- Highlight
- Email to a Friend
I have downloaded twice, installed twice; but there is still no button in the REX extensions ribbon, neither RST or RAC.
I have 2 addin files in the addins directory, named Autodesk.RevitStructureExtensions.Revit.addin and Autodesk.RevitArchitectureExtensions.Revit.addin.
built is 20110916f_2132(x64), update release 2.
help needed. Thanks.
PS: country: France
- Highlight
- Email to a Friend
1. Create contours on desired levels
2. Create form based on selected contours (option Create form)
3. Divide surfaces based on selected form (option Divide surface)
4. Apply meshing pattern in Properties dialog (f.ex. rectangle)
In-place families are not supported.
For famillies it will not be possible to update the file with structural elements
- Highlight
- Email to a Friend
Please, try the following:
For the moment you need to move c:\Program Files\Common Files\Autodesk Shared\Extensions 2012\Modules\Modeling\ABuildingGeneration\en-US\ ABuildingGeneration_revit.xml file into
c:\Program Files\Common Files\Autodesk Shared\Extensions 2012\Modules\Modeling\ABuildingGeneration\Configur
- Highlight
- Email to a Friend
Thanks Pawel, it works now.
I will add something to your previous comment:
1- new family, Mass
2- create form
3- divide mass
4- load in the project
5- run structure generator
more feedback to come....
- Highlight
- Email to a Friend
Updated version is available for download. List of corrections:
1) Problem with installation on non-english systems
2) Problem with selection on viewer (caused by incorrect contour presentation)
3) Problem with beams position in case of masses with irregular shape
4) Help file updated (screenshots with examples)
An old version should be unistalled before.
- Highlight
- Email to a Friend
For the moment, if you have installed the latest version (from 29.11.2011) without installing the previous one (from 23.11.2011), the application may not run on 64-bit machines. (A message Assembly name: ABuildingGeneration: Method not found: 'Void CBSEngine.IRobinViewDisplay.ShowObjectsAndShadows(
In this case, one should unpack and copy manually the attached file into directory C:\Program Files\Common Files\Autodesk Shared\Extensions 2012\Framework\Interop\
- Highlight
- Email to a Friend
The corrected installer has been posted on the Autodesk Labs web site. The file name is Revit_Structure_Generator4.exe. This will avoid the problem for people who have yet to download the technology preview. Users who are experiencing the problem can uninstall and install this corrected version.
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
- Highlight
- Email to a Friend
Anyone knows why it doesn't work with a circular structure?
I'tried a silo with the shape of a cilinder, but the default structure generated looks very strange, even if I take a smaller mesh.
Also when I manualy enter two curved structural lines to make a circle I can't generate a grid.
