• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Structure
    Valued Mentor
    AJA14
    scale issue in sheets
    222 Views, 4 Replies
    04-12-2012 04:27 AM
    Hi. I have a master plan thats very large so I created several duplicates as dependants so that I can place them in different sheets and show them better. The problem is, I want the master plan to have a scale different from the dependents. They both are placed in different sheets. How can I do that. If I duplicate without being a dependent then my changes in one will not affect the other and I will have to do the work twice for every duplicate.
    Ali Al-Hammoud
    Structural Design Engineer
    MZ & Partners Engineering Consultancy
    Please use plain text.
    Distinguished Contributor
    Re: scale issue in sheets
    04-16-2012 08:49 AM in reply to: AJA14
    We do this all the time.
    Whatever you MODEL will be modeled in ALL scale plans.  The difference is your View Settings and your annotation.
    We, typically, do not duplicate annotation between 1"=20' Overall Plans and our 1/8" scale Partial Plans.  We use our Overall Plans more for general information, overall dimensions, etc., while our 1/8" scale dependent plans are used to really document the project.
    Leanne Zaras, CDT, LEED AP
    AutoCAD 2010 Certified Professional
    Revit Architecture 2012 Certified Professional
    Valued Mentor
    AJA14
    04-17-2012 01:55 AM in reply to: lzaras1
    Hi. Thanks for answering. I think you misunderstood my question. Suppose I have plan A which is very large and needs to be scale 1/300. Then I need to seperate into 3 or 4 plans scale 1/100 to become readable. If i duplicated the plan without being a dependent then I would have to do any changes in plan A in all of its parts. So I duplicated the parts as dependents. Now whenever I change the scale of any part, the main plan A's scale will change as well. I understood from your response that u do this all the time. I was just wondering if I could do it and still have my parts as dependant duplicates of the master plan A. thanks in advance.
    Ali Al-Hammoud
    04-18-2012 10:34 AM in reply to: AJA14
    you asked, "... I was just wondering if I could do it and still have my parts as dependant duplicates of the master plan A...."
    No.  In essence, you'll have TWO "overall" plans.  One for each scale.  Your 1/300 will be your Overall plan.  Your 1/100 will be the overall plan for your dependant/ partial plans.
    Active Contributor
    05-03-2012 05:57 AM in reply to: AJA14
    do your seperate plans as callouts, this way you can change the scale of each accordingly without affecting the other, plus when you make a change to the master plan it will also change in the callouts. hope this helps.
