• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Structure
    Active Member
    chad2472
    "bring to front" dimensions
    86 Views, 0 Replies
    11-16-2012 09:13 AM
    Hi Everyone. I am having a problem with dimensions and making them opaque. I want to use "Bring to Front" to solve it, but Revit does not give me this option.
    To detail out my problem: I have a dim style style setup to make dimesion text mask out objects behind it. The problem we are having is that if I draw one dimension, then draw a second dimenion that is over top of the first dim's text the second's extension line is not hidden behind the text. If I delete the first text and redraw it, it will then hide the second dim's extension line. The proper solution is to use "Bring to Front" to fix it. But Revit is not giving me this option. I am using 2011 right now. Has this been fixed in newer versions of Revit, or did the programmers never figure we would need to do that?
    Thanks Chad
    Please use plain text.
