• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Structure
    Valued Contributor
    huyxp
    how do you draw slab in revit?
    189 Views, 2 Replies
    07-03-2012 11:50 PM
    hi all
    when i draw slab in revit i don't know draw slab for true?
    boundary of slab is edge outside of beam or edge interior of beam??
    Please use plain text.
    Valued Mentor
    AJA14
    Re: how do you draw slab in revit?
    07-04-2012 08:27 AM in reply to: huyxp
    The edge should be outside of the beam. However, if you are planning to later work on transferring the model to Robot, then you have to do some work on the analytical model.
    Ali Al-Hammoud
    Structural Design Engineer
    MZ & Partners Engineering Consultancy
    engr_mondo
    07-04-2012 07:25 PM in reply to: AJA14
    Another point is the slab volume--check values of modeled outside vs inside the beam edges.
    Mondo
