Autodesk Revit Structure
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
beam labelling and automatic schedule key
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Evening All,
I'm trying to deal with a pretty specific task but after many hours scouring google and youtube I'm pretty stumped. I'm new to Revit Structure. I've got an imported steel first floor 2D beam plan in my revit model which currently shows the beam types "203x203x46 UC etc". I need to do 3 things:
1) update the first floor plan, getting Revit to logically sort and update the beam labels from the above steel size into logical beam labels e.g.
B1 = 203x203x46 UC
B2 = 533x210x82 UB
etc.
2) generate (I'm hoping automatically) a logical reference table:
beam label | beam size |
B1 <beam sizes>|
B2 | |
B2 | |
etc | |
3) create a CAD DWG of this first floor plan incorporating the labelling logic and key table above.
If there is an app or add-in for revit that helps (I have the horrible feeling I'm going to have to do this the hard way but worth checking) please let me know.
Any help would be greatly appreciated! ![]()
Many Thanks,
Scott
Re: beam labelling and automatic schedule key
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Oh I'm using Revit Structure 2012 by the way if that helps too ![]()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi There,
Well I've investigated creating a beam schedule but it doesn't seem to have any option to connect the schedule table of beams (as sketched above, B1, B2 etc) to the actual beam tags and there seems to be no post on this forum relating to it. Very suprising.
This must be a pretty sought after feature for drafting, does any exeprt on here know how to do the 3 step process I mentioned in the first post? Or is there an add-on that helps in this area?
Many Thanks,
Scott
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi. I am not sure if I understand you completely but what you're trying to achieve should not be difficult. Usually, for tagging, if you can't find what you need you can modify an exisitng tag family and incorporate new parameters. If the parameter you need isn't there, then you can create shared parameters. These can also be used in a schedule to report your beam labels and so on. Let me know if I can be of further assistance.
Structural Design Engineer
MZ & Partners Engineering Consultancy
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi AJ,
Many thanks for the tips
I'm guessing the main hurdle would be to get revit to perform step 1 in my first post. I can't find any option for doing it
. I can add tag's manually B1, B2, etc for each beam but the objective is to get revit to logically and automatically tag B1 to all beams of a specific sizes, B2 to another steel size, and so on. If you can provide any advice on how to do this it would be greatly appreciated!
Scott
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi, well, performing the first task isn't that hard. First of all, you need to use the Tag All Not Tagged and choose the structural framing and assign the correct tag to use. The main idea is that the tag family you choose is the one you need to apply to all these beams. Since the tag family may not exist already in revit you need to create one yourself either by starting from and existing tag or starting with a new revit family template. Let me know if I can be of any assistance.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks AJ
I'll give it a go tonight
