Autodesk Revit Structure
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
area reinforcem ent boundary in revit structure 2013 visibility
- Highlight
- Email to a Friend
Hi. The area and path reinforcement can't be turned off in revit structure 2013. There seems to be a bug and the overrides don't work. In addition, you can't even use the Linework tool to make them invisible. Any idea why this is happening.
Structural Design Engineer
MZ & Partners Engineering Consultancy
Re: area reinforcem ent boundary in revit structure 2013 visibility
- Highlight
- Email to a Friend
I would also like to know the reason for this, and to be fixed ASAP!
Seems the system families have been corrupted between 2012 & 2013. The boundary is now linked to the Area Reinforcement rather than the - Area Reinforcement Boundary. This is clearly an error that Autodesk must fix.
Ps. Autodesk. Pick up your game!
- Highlight
- Email to a Friend
I'm also having the same problem. I can't hide the boundary box for Area Reinforcement. Would love it if Autodesk would fix the Visibility/Graphic bug also. If someone else has a work around that they are using. please let us know.
- Highlight
- Email to a Friend
I have found sort of work around (not really a fix).
I normally have my slab shaded in a light grey and found that if I select the suspect rebar boundary that
I could override graphics in view (the paint brush under the light globe) I would make the colour of the boundary the same as what ever the slab is. This in essence makes the boundary invisible.
Hope it helps and AutoDesk release a patch.
- Highlight
- Email to a Friend
Hi. haven't been able to post. The solution is easy, just change the area reinforcement color to white in the object styles and the area boundary will disappear. Regards.
- Highlight
- Email to a Friend
Thanks for the work around that you posted. It works very well. The only thing that I'm running in to now is that. If one place the boundary box over slab edges or beams they will not print out. I have tried changing the line type to dots or some other open type of line style. That didn't work. The only fix I have found was to have the boundary box offset a little so the other lines show up. I'm hope that you found a better way.
thanks again for your help.
- Highlight
- Email to a Friend
Hi. If you use my workaround, (Changing color or area reinfocement to white), the edges of slabs should print normally since the white lines do not mask the boundaries of beams or slabs. Anyways, I will recheck this issue and post if I find anything with this regards.
