Autodesk Revit Structure
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Wall Footings Claim that Elevation at Bottom Varies When It Really Doesn't
- Highlight
- Email to a Friend
Scott Johnson, Ph.D.
CAD/BIM Manager
Richard L. Bowen + Associates
Re: Wall Footings Claim that Elevation at Bottom Varies When It Really Doesn't
- Highlight
- Email to a Friend
I've noticed the same thing and wondered the same - and I've only been
trying to use the program for a very short time. I don't know if I'm
misusing the software or if Revit is just not ready for prime time yet.
I don't know if the developers ever had work experience in creating
structural drawings or not. I am trying not to become overly frustrated
with Revit's limitations and Prozac speed. I'm hoping things will get
faster as my understanding improves.
I find it disconcerting (to say the least) that the simple basic questions
I've posted thus far have for the most part gone unanswered or just answered
with a 'Revit does not do that'. (This might be the answer, but it is not
the CORRECT answer, Autodesk.) (Perhaps Autodesk's hoisting their
newsgroups by its own petard has something to do with the lack of
traffic/feedback/answers/replies/workarounds? I don't know.)
I hope someone can provide you with a better answer. At least know that
you're not alone.
David Kozina
We are having a problem with wall foundations that claim that their
Elevation at Bottom varies, when in fact it does not. An example is shown in
the attached image. The longer of the two wall footings correctly indicates
that its Elevation at Bottom is -1'-4", until it joins with another wall
footing of the exact same type and Elevation at Bottom. Once it joins with
another, it incorrectly indicates that its Elevation at Bottom "Varies."
(The other foundation continues to correctly report it's Elevation at Bottom
as -1'-4".) The incorrect value for the longer footing messes up footing
schedules and tags in the foundation plans. I figure that this has to be a
bug, but I found no mention of it in this forum, and only one mention of it
at AUGI (http://forums.augi.com/showthread.php?p=900909#po
00909){color:#000000}.{color} I posted a copy of a simple .rvt file with
this problem in a post in the aforementioned AUGI thread. Is there something
specific that triggers this misreporting of elevation? Anything we can do to
avoid it? Revit becomes much less useful when it starts misreporting its
data.
CAD/BIM Manager
- Highlight
- Email to a Friend
Was there ever a solution found to this problem? Having the same issue.
- Ryan
- Highlight
- Email to a Friend
I have the same problem where the footing parameter lists the bottom of footing elevation as "Varies" but when I take an annotative elevation of it, it at leasts reports the proper elevation. I don't typically tag the bottom of footing elevation as other people do, so it's never been an issue for me. Not sure, maybe it's something innate with the tag?
- Highlight
- Email to a Friend
try editing the footing type by changing the thickness to something different and then edit it again turning it back to the right thickness
- Highlight
- Email to a Friend
timstephenson,
Changing the thickness does not seem to help, the footing elevation only seems to vary once walls are joined with one another. If I unjoin or split them the footing elevations show the same elevation.
