Autodesk Revit Structure
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Unable to create Beam to CIP Wall Connection
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I would like to detail in a 3d connection (steel plate and all) of a Beam to a concrete wall. I have the " Steel Connections" extension from Autodesk and it is missing this ability. Is there anyway to create this connection?
Re: Unable to create Beam to CIP Wall Connection
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You could either create a callout, and use detailing to get what you need, or you would create a drafting view and do it as you would in autocad, using 2d drafting. Still waiting on Autodesk to improve this area.
Structural Design Engineer
MZ & Partners Engineering Consultancy
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
So there is no way to model this connection three dimensionally? Has anyone ran into this situation and found an extension, plugin or work around?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
to do it as a 3D model element, you would have to export to ASD or TEKLA, do the connections theri, and import them back to revit. I haven't personally done that, but I know people who have used tekla for this, and I went to an Autodesk seminar and asked this question and his answer was to use ASD (Autocad Structural Detailing).
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks AJA14, I tried to use ASD yesterday to create this connection but ran into many problems ( first time using it was most likely the main problem). Do you know if when you import the ASD connection into Revit does it show up as a 3d object or is it a 2d cad file? Also I am assuming it does not have any information that can be attached to the object if so.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi. anything you export to ASD or TEKLA will come back in 3D. However, another option would be to buy SDS/2 connect and use it. It is an add-in for revit but it is expensive (1500 dollars). However, it is available for free trial for 30 days. I suggest you install and try it and it may be what you're looking for. Regards.
