Autodesk Revit Structure
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Thickened slab footings
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
\_____/
I cannot seem to modify a wall footing type to have the 'beveled' sides.
Even if it turns out that I can get beveled sides, how would I add a 'wall'
footing without the wall? (Usually we provide these footings below
non-bearing walls, which we don't typically draw or show.)
IOW, I just need a footing inserted inside the slab on grade, kind of like a
thickened slab edge (and it's mirror) without the edge.
Any suggestions would be appreciated.
David Kozina
Re: Thickened slab footings
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
family. Edit the family to have the beveled sides and place it in the
project paying attention to where the top of the beam/thickened slab is
located.
Leannie
"Not only is life a bitch, but it is always having puppies."
- Adrienne Gusoff
"David Kozina" <"David Kozina"> wrote in message
news:6065506@discussion.autodesk.com...
How do you create thickened slab footings?:
\_____/
David Kozina
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I will look into this. Thanks much for the reply!
David Kozina
"Zaras"
news:6066454@discussion.autodesk.com...
I actually ended up having to create a new family using a Concrete Beam
located.
Leannie
- Adrienne Gusoff
\_____/
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I was just wondering if you had any luck creating a thickened slab with the bevelled edges. I posted a similar topic and was just wondering if there was any progress, as well what is the possibility of getting the family you created. I am new to revit and I am having difficulty trying to create a new family.
any help would be appreciated.
kevin
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am also having issues with thickened slabs with the bevel on both sides.
Has there been any success for anyone? Has anyone been able to make the "concrete beam with beveled edges" idea work?
Thanks in advance!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
How about making an inplace foundation family. Make a profile of the section with the top at the bottom of the slab. Create a sweep and trace the nonbearing wall locations.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yep, I did this about a week ago. I created a new wall type with a sweep and also for the different wall thicknesses i use. when you have a deadline it is amazing what you can figure out.
Thanks anyway
