• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Structure
    Distinguished Contributor
    Tagging Beame steel
    281 Views, 7 Replies
    12-21-2012 07:12 PM
    Hi. I verry like revit.
    You can tutorial creative Tagging same picture?
    THanks.
    Please use plain text.
    Re: Tagging Beame steel
    12-27-2012 02:51 AM in reply to: A.wikipedia
    Please help? Thaks
    01-05-2013 04:34 AM in reply to: A.wikipedia
    Plaese.
    I is verry need.
    01-08-2013 06:54 AM in reply to: A.wikipedia
    Hi. Plase help me ??????
    01-09-2013 06:01 AM in reply to: A.wikipedia
    Perhaps you could elaborate and explain a little bit more about what you want, and maybe that will catch someone's interest a little better?
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Employee
    Joe.Charpentier
    Re: Tagging Beam steel
    01-09-2013 12:19 PM in reply to: A.wikipedia
    It looks like you are trying to tag rebar with various pieces of data.
    The rebar family would have to have all of the data attached as properties, and you will need to edit/create a tag family.  (Select a rebar tag in the Project Browser, right click to duplicate it, then right click to edit the family.)
    You could use a multi-parameter tag to compile the first part of the tag- a diameter symbol (which may be part of the type name), the bar diameter (a type property, or it could be part of the type name), and then, I’m not sure what the “200” represents- length, or a shape name?
    You can draw the lines and the circle in the tag family, and set the leader to use an arrowhead. Again, I’m not sure what the data in the circle is supposed to represent, but if the data part of the rebar family, you can create a second label to report it, or you may have to get into Shared Parameters if it’s some kind of custom data..
    Joe
    01-09-2013 07:28 PM in reply to: Joe.Charpentier
    Thank two you.
    But you can create given me tag steel file revit of me. Thanks.
    File revit
    http://www.mediafire.com/?x72a16904cpwg80.
    Employee
    Joe.Charpentier
    01-11-2013 05:30 AM in reply to: A.wikipedia
    I'm sorry, I still don't understand exactly what you need.
    I reccomend learning more about the family editor so you can customize Revit elements to your own specifications.
    Joe
