• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Structure
    Distinguished Contributor
    Subscription Revit Structure 2012 Vibration Analysis Add On
    235 Views, 5 Replies
    09-11-2012 02:02 PM
    Which Subscription download contains the Floor Vibration Analysis addon for Revit Structure 2012? I've found the one for 2011, but no 2012.
    Please use plain text.
    Product Support
    fernanda.firman
    Re: Subscription Revit Structure 2012 Vibration Analysis Add On
    09-20-2012 03:36 PM in reply to: RocksterB
    If you have subscription you can download Revit Structural Extension for 2012.
    After downloaded, Floor Vibration Analysis should appear under  Extensions> Analysis (see attachment)
    http://blogs.rand.com/files/revitext_rst2012_featuresummary_20110601.pdf
    Hope that helps.
    Fernanda Lima Firman
    Revit Support Specialist
    Revit Clinic
    If this helped solve your issue - remember to 'accept as solution' to help others find answers.
    09-20-2012 03:40 PM in reply to: RocksterB
    Specifically, what is the name of the files? Thanks!
    Product Support
    fernanda.firman
    09-20-2012 03:55 PM in reply to: fernanda.firman
    The name is exactly like in the pdf file I sent you: Revit Extensions for Autodesk Revit Structure 2012.
    The Floor Vibration is listed in the pdf document under the Appendix.
    Revit Clinic
    09-20-2012 03:56 PM in reply to: fernanda.firman
    Okay, I'll have a look in the morning.
    09-21-2012 12:16 PM in reply to: RocksterB
    So I was right, I do have the correct extension installed on my PC, but the panel for the extension doesn't show doesn't show. See that attached image. Why might that be?
