Autodesk Revit Structure
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Subscripti on Revit Structure 2012 Vibration Analysis Add On
- Highlight
- Email to a Friend
Which Subscription download contains the Floor Vibration Analysis addon for Revit Structure 2012? I've found the one for 2011, but no 2012.
Re: Subscripti on Revit Structure 2012 Vibration Analysis Add On
- Highlight
- Email to a Friend
If you have subscription you can download Revit Structural Extension for 2012.
After downloaded, Floor Vibration Analysis should appear under Extensions> Analysis (see attachment)
http://blogs.rand.com/files/revitext_rst2012_featu
Hope that helps.
Fernanda Lima Firman
Revit Support Specialist
Autodesk, Inc.
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
- Highlight
- Email to a Friend
Specifically, what is the name of the files? Thanks!
- Highlight
- Email to a Friend
The name is exactly like in the pdf file I sent you: Revit Extensions for Autodesk Revit Structure 2012.
The Floor Vibration is listed in the pdf document under the Appendix.
Autodesk, Inc.
- Highlight
- Email to a Friend
Okay, I'll have a look in the morning.
- Highlight
- Email to a Friend
So I was right, I do have the correct extension installed on my PC, but the panel for the extension doesn't show doesn't show. See that attached image. Why might that be?
