• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Structure
    Active Contributor
    Structural Stair
    189 Views, 1 Replies
    10-24-2012 07:37 PM
    Hi everyone,
     I find it’s very hard to handle stairs with Revit Structure because Revit-Stair-function was designed for Architects instead of structural engineers.  For example, structural stairs are under 2-inch topping of arch stair, but Revit-Stair
    can’t offset the stair  2-inches, I have to do lots of additional work to finish stairs( it’s really a lot of work). Do you have a special way  to handle this issue? Please see the attached picture for detail.
    Jason
    Please use plain text.
    engr_mondo
    Re: Structural Stair
    10-28-2012 09:56 PM in reply to: li71we
    Just be consistent--if your using RST levels (Bottom and Top) is at TOP OF CONCRETE, there should be no problem. I personaly used structural levels in RST.
    Mondo
