• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Structure
    Active Contributor
    Steel connections
    346 Views, 3 Replies
    06-12-2007 12:48 AM
    Does anyone knows if there is future in Revit_S as far as steel design is concerned? When someone will be able to draw steel connections in revit easily and full parametric?
    Please use plain text.
    *Robert Vetrano
    Re: Steel connections
    06-18-2007 07:47 AM in reply to: Mazis
    Created a bunch of adjustable connection in RS2( clip angles, momment conn,
    base plates, wing plates, thru column plates). Then with the API and Visual
    Studio.Net 2003 created routines that would adjust everything to member
    sizes.Then heard rumor that Autodesk was working on steel connection so I
    figured why waste my time. API doesn't work with RS8 and just haven't
    gotten around to upgrading it.
    Perhaps Joe Charpentier could shed some light on Autodesk plans or rumors
    he's heard.
    bob v
    wrote in message news:5623172@discussion.autodesk.com...
    06-21-2007 08:43 AM in reply to: Mazis
    Dear Moog,
    Right now we don't necessarily focus on connection modeling, but using families you can definitely do it. we actually ship some of them in the box
    are you working for a design firm or a detailer/fabricator ?
    Active Contributor
    06-22-2007 04:07 AM in reply to: Mazis
    I am working for a design firm.Could i have these families somehow?
