• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Structure
    Active Contributor
    awes
    Accepted Solution
    Slab edge doesn't host rebars
    170 Views, 3 Replies
    10-27-2012 03:12 AM
    Hi! I'm not able to put rebars into slab edges based on library slab edge profile (RVT 2013 at least FIN GER SWE language packs). Any clues? There's no option to tick 'host rebar' profile family, profile type is slab edge and material is structural concrete.
    Please use plain text.
    Product Support
    fernanda.firman
    Re: Slab edge doesn't host rebars
    11-01-2012 12:56 PM in reply to: awes
    I have no problem adding rebars into a slab edge.
    Can you please describe how you are trying to place the rebars?
    Can you add it in section view?
    Fernanda Lima Firman
    Revit Support Specialist
    Autodesk, Inc.
    Revit Clinic
    If this helped solve your issue - remember to 'accept as solution' to help others find answers.
    Active Contributor
    awes
    11-04-2012 01:49 AM in reply to: fernanda.firman
    Dear Fernanda, my problem seems to be solved.
    I'm now able to put rebars in slab edges based slab edges & profiles from structural project templates as well as slab edges based on profiles created by my own.
    I'm not able to recreate the a slab edge that cannot host a rebar and yes I can now see the the structural property rebar cover. In the first hand I wasn't able to add rebars in any views using different options and my guess is that the original problem was related to a wrong chosen profile family template. I'm although sure that I used a profile with structural properties, profile usage slab edge and structural material as structural concrete.
    I have an additional question related to profiles for structural use. Is there a family parameter for hosting rebars or is it a bonus that comes with  structural material or type of usage? Many thanks for your answer in advance.
    Valued Mentor
    AJA14
    11-04-2012 09:29 PM in reply to: awes
    Hi. I'm not sure if this is your question, but any family that has the structural property enabled in the instance properties will be able to host rebars. So make sure you use a structural family to start a new one and enable structure to be able to host rebars.
    Ali Al-Hammoud
    Structural Design Engineer
    MZ & Partners Engineering Consultancy
