So, since the nested shelving Families are not Shared, the nested components will not be Scheduled separately. This means that you do not need the "JUMBO_Product Section Code" Parameter in the nested Family. This is because there is no way for the host Family to "read" this Parameter from a nested Family.
I believe that the solution here is to add "JUMBO_Product Section Code" to the host Family and create an additional <Family Type...> Type Parameter that corresponds to each possible selection. That will allow you to control "JUMBO_Product Section Code" with a formula, based on the value of "JUMBO_Product Section Description". Here's what I propose:
In the host Family, create these <Family Type...> (Casework) Parameters as Type Parameters, and set them to the value listed.
Name Value
JPSD_1 SECTION / ΚΑΤΗΓΟΡΙΑ : TOYS / ΠΑΙΧΝΙΔΙΑ
JPSD_2 SECTION / ΚΑΤΗΓΟΡΙΑ : CLOTHING / ΡΟΥΧΟ
JPSD_3 SECTION / ΚΑΤΗΓΟΡΙΑ : SEASONALS / ΕΠΟΧΙΚΑ
JPSD_4 SECTION / ΚΑΤΗΓΟΡΙΑ : HOME PRODUCTS / ΟΙΚΙΑΚΟΣ ΕΞΟΠΛΙΣΜΟΣ
JPSD_5 SECTION / ΚΑΤΗΓΟΡΙΑ : OUTDOOR / ΕΙΔΗ ΕΞΩΤΕΡΙΚΟΥ ΧΩΡΟΥ
JPSD_6 SECTION / ΚΑΤΗΓΟΡΙΑ : ELECTRONICS / ΗΛΕΚΤΡΟΝΙΚΑ ΕΙΔΗ
Now, add "JUMBO_Product Section Code" to the host Family, and apply the following formula (you can Copy/Paste):
if(JUMBO_Product Section Description = JPSD_1, 1, if(JUMBO_Product Section Description = JPSD_2, 2, if(JUMBO_Product Section Description = JPSD_3, 3, if(JUMBO_Product Section Description = JPSD_4, 4,if(JUMBO_Product Section Description = JPSD_5, 5, 6)))))
Now, the Integer Parameter "JUMBO_Product Section Code" will be driven by the dropdown "JUMBO_Product Section Description", thus allowing you to Filter your Schedule by the Section Code. If you have to add more shelving types, just create additional <Family Type...> Parameters as above and add another nested IF/THEN Statement to the formula.
Don't hesitate to post with questions, or if I've misunderstood your intentions.
Corey D.
──────────────────────────────────────────────────────────────────────⁞|⁞ Please use
.Accept as Solution and
Give Kudos as appropriate to further enhance these forums. Thank you!
