• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Structure
    *Expert Elite*
    BrianHailey
    Re: Revit Structure Extensions Not Showing Up
    12-12-2012 11:19 AM in reply to: DarrenP
    You must have tried it just after I posted it. I noticed it didn't work as well so I fixed it.
    You're fast!
    Please use plain text.
    *Expert Elite*
    DarrenP
    12-12-2012 11:23 AM in reply to: DarrenP
    it doesn't seem to be installing the extenstions correctly on this machine
    does the install work on other machines?
    *Expert Elite*
    DarrenP
    12-12-2012 11:24 AM in reply to: DarrenP
    if it does you can try copying those .addin files from that machine to your machine
    *Expert Elite*
    BrianHailey
    12-12-2012 11:25 AM in reply to: DarrenP
    Perhaps I got a bad download. I'll try again.
    Employee
    Joe.Charpentier
    12-12-2012 01:26 PM in reply to: DarrenP
    There should be two downloads for the Extensions for r2013.  The second is marked "q3" and is the most recent.  Is that the one you are using?
    You need to install the original release of the 2013 extensions and then the Q3 release.
    Joe
    *Expert Elite*
    BrianHailey
    12-12-2012 01:48 PM in reply to: Joe.Charpentier
    Aha! See, there was nothing there that said you need to install both of them so I just went with the latest one. I figured it was like a service pack, you only need the latest one (at least that's the way it is for Civil 3D). Downloading now. I'll let you know the results.
    *Expert Elite*
    BrianHailey
    12-12-2012 04:04 PM in reply to: Joe.Charpentier
    Joe
    That was it! Thanks so much!
    I hang my head in shame for not realizing this.
    *Expert Elite*
    DarrenP
    12-12-2012 04:31 PM in reply to: BrianHailey
    i guess i should of started with the  easy questions first
    Employee
    Joe.Charpentier
    12-13-2012 04:18 AM in reply to: BrianHailey
    Don't feel bad- the only reason I know this is I did it myself.
    Sorry it took so long.
    Joe
    Member
    01-03-2013 08:40 PM in reply to: BrianHailey
    Do you using extension Civil 3D Surface to Revit is For what? I think you using for topo surface, thus why you can't find out from extension. You go and search topo robbin tap. I think is right.
