• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Structure
    Active Member
    Revit Structure 2011 hangs on Splash Screen
    123 Views, 0 Replies
    04-27-2012 11:38 AM
    Having a helluva time getting revit structure 2011 to run on a users machine. Structure 2012 runs fine. 2011 hangs at the splash screen and then a Windows error comes up saying the program has stopped responding. I've done all the usual tricks:
    1. Restart PC
    2. Uninstall/reinstall Revit
    3. Checked the WSommcntr2.exe process (its not running)
    4. Tried to delete WSCommcntrdata.xml, but it doesn't exist. Probably because 2011 has never started.
    5. Deleted UIState.dat
    6. Tried to launch from a different user profile
    7. Repair install of .NET framework 4
    8. Set registry for launching CommCenter to 0
    I'm still getting the same error. I will attach the Application Log, the actual Windows error codes and the Revit Journal from the latest attempt to launch it. I'm at a standstill. Any help would be greatly appreciated
    Please use plain text.
