Autodesk Revit Structure
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Problem with revit extensions
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi. This is what happened when trying to add reinforcement for columns using the extensions. Any ideas.
Structural Design Engineer
MZ & Partners Engineering Consultancy
Re: Problem with revit extensions
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
My assumption is that you still work with the original 2013 version of REX. Please try to download and install its newer version (2013Q3) where this issue should be corrected. The newer version replaced the older one on Subscription site.
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Artur. I downloaded the updated extensions but still facing the same problem. I don't have this problem with other projects so I don't think it is only related to the extensions.
This is a 30 floor tower with a central file and 5 locals and about 8 worksets. Do you think that this could be the cause of the problem.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I can't tell without having a chance to check. Could you try to isolate the column where this happens and save it in a 'new' Revit file. If you still have the same situation attach this file.
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi. Artur. Take a look at the attached file. If you notice that the revit extensions will not work eventhough all I have is one column and a sheet.
However, what's weird is that if I delete sheet from the project browser and then use the extensions, it works.
Regards.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I can't see such problem.
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That's really strange. Like I said, when I delete all my sheets, it works fine. Anyways I'll let you know what I find out.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Please check which version of REX you have installed as shown on the attached picture.
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Artur. I have a different version. See attached image. Although I did install the latest from the autodesk website. Could you please provide a link to the correct version. I would really appreciate that.
Regards.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It is available from the Subscription site (see the attached picture).
Artur Kosakowski
Support Specialist
Product Support
