• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Structure
    Member
    Problem with revit extensions (Beam to Column Connection)
    339 Views, 4 Replies
    02-20-2013 03:16 AM
    I have the same issue with steel connections and rafter framing. All latest extensions and updates installed.
    Please advise
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Problem with revit extensions
    02-20-2013 03:23 AM in reply to: csouch
    These are different Extensions and the solution I suggested is based on the screen capture attached to this post and this particular Extension.
    My understanding is that you have already registered as support case for the rafter framing but what is the exact issue with the steel connections?
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Member
    02-20-2013 03:56 AM in reply to: Artur.Kosakowski
    Please see photos on the errors on the steel connections. These have worked well for me on a previous model.
    Product Support
    Artur.Kosakowski
    02-20-2013 04:00 AM in reply to: csouch
    As you have created the support request for this issue I will communicate with you within this support case.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Product Support
    Artur.Kosakowski
    02-20-2013 06:51 AM in reply to: Artur.Kosakowski
    This REX supports only I type sections.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
