• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Structure
    Active Contributor
    MIKEFETTKETHER4651
    Accepted Solution
    Label Bay's
    181 Views, 6 Replies
    10-04-2012 02:18 PM
    I'm laying out this huge factory facility in Revit.  Inbetween each column line the bay's are labeled in the factory.  Does anyone know of a good way to label the bay's in Revit?
    Revit Structure 2013
    Please use plain text.
    Product Support
    Chris.Aquino
    Re: Label Bay's
    10-08-2012 06:57 AM in reply to: MIKEFETTKETHER4651
    I would think regular Text would be the easiest way to label the bays.
    If the does not work for you, please reply with more information about what you are trying to do so that we can provide a better answer.
    Chris Aquino
    Revit Support Specialist
    Autodesk, Inc.
    The Revit Clinic
    @Revitclinic
    Active Contributor
    MIKEFETTKETHER4651
    Re: Label Bay's
    10-10-2012 01:03 PM in reply to: MIKEFETTKETHER4651
    I'm looking for something that when I'm zoomed into a specific area I can tell which Bay I'm currently in without referencing the column grid or zooming out to the full plan view.  The only think I could think of would be to place rooms for each bay.  With rooms I should be able to find in view from a schedule.  Can anyone else think of a better idea?
    Active Contributor
    Re: Label Bay's
    10-11-2012 03:04 AM in reply to: MIKEFETTKETHER4651
    Maybe a transparant detail item which van be tagged ? Or a genereic model without 3d data, only with some lines for example. This one can be r4ead in schedules.
    Just some ideas.
    Regards, Jordi
    Product Support
    Chris.Aquino
    Re: Label Bay's
    10-15-2012 12:18 PM in reply to: MIKEFETTKETHER4651
    Room Elements would be a good option, as they flow to fill the area, and can be tagged and scheduled. However, they'd all have the same fill pattern, so it may be hard to differentiate visually. A detail element may work, but depending on how many different bays you have, you may end up with a large number of them.
    Chris Aquino
    Autodesk, Inc.
    The Revit Clinic
    @Revitclinic
    Active Contributor
    MIKEFETTKETHER4651
    Re: Label Bay's
    10-15-2012 01:21 PM in reply to: MIKEFETTKETHER4651
    I would love to try the Room's options, but I only have Revit Structure.  It does not look like I have the option to create rooms unless you have the Architectural version.  So I will probably have to do something else like the option you suggested.
    Mike
    Product Support
    Chris.Aquino
    Re: Label Bay's
    10-15-2012 01:43 PM in reply to: MIKEFETTKETHER4651
    As room elements, the detail elements are probably your best bet.
    Chris Aquino
    Autodesk, Inc.
    The Revit Clinic
    @Revitclinic
