• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Structure
    Active Member
    I have a problem
    190 Views, 3 Replies
    02-07-2013 11:28 AM
    Need some help,  I have a curtian wall in my model that won't delete. I placed it in the wrong spot. I can click on it, but It wont delete. It wont move and, on the properties panel everything is grayed out. It only shows up in an elevation view. Any help/
    Please use plain text.
    *Expert Elite*
    Bob_Zurunkle
    Re: I have a problem
    02-13-2013 09:20 AM in reply to: aaron-shaeffer
    Is it part of someone else's workset?
    If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
    Active Member
    02-13-2013 10:29 AM in reply to: aaron-shaeffer
    Some one helped me. They could not get the part to delet, but they used a filter and made it go away. Kind of weird.  Thanks
    Valued Contributor
    02-13-2013 11:22 AM in reply to: aaron-shaeffer
    Doesn't really make sense...the filter will only "turn off" the curtain wall in that view.  Sounds like it still exists in your model.  Probably worth digging into a little further to see what the  problem is and how to actually delete the curtain wall. It may become an issue later.
