• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Structure
    Member
    How to make Autodesk Revit run more smoothly with 8-core?
    169 Views, 2 Replies
    11-06-2012 11:46 PM
    My computer has 8 cores. When the Autodesk Revit is running,
    the computer shows that only one of the eight coreis processing.
    The other seven cores are not being used at that time.
    How can I use the other seven cores together to make the Autodesk Revit run more smoothly
    and quickly?
    My processor model number is Intel(R) Core(TM)i7 CPU  950 @  3.07GHz   3.07GHz
    Looking forward to your soonest reply.
    Best regards & Thanks,
    Kevin
    Please use plain text.
    Active Member
    Re: How to make Autodesk Revit run more smoothly with 8-core?
    11-07-2012 02:30 AM in reply to: 732861
    Which version are you running?
    Then look at tht post http://revitit.com/blog/?p=443
    Valued Contributor
    11-19-2012 12:23 PM in reply to: dhurtubise
    Thanks for this link. I set all my cores to 100% and it made a significant improvement working with large models.
