Hollow core as a slab part
MeelisSinijärv6719
MeelisSinijärv6719
Here is a link to a youtub video http://www.youtube.com/watch?v=1kslQ9P1160&feature=plcp where the guys are defining hollow core panels as parts of a floor element.
Can anyone explain how they can make a part look like a hollow core?
MeelisSinijärv6719
I figured it out. They used floor based void family to cut the hollows out of the floor and then created the parts according to the panel contours. It's quite a good solution of making hollow core slabs. One advantage is that you do not need to modify panels individually (if angled cuts or shaft cuts) but you can get specific data for each individual panel. And no problem because of automatic joints with beam like hollw cores.
