• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Structure
    Valued Contributor
    Hidden corbels of precast column appear unwanted
    174 Views, 3 Replies
    02-07-2013 05:41 AM
    Insert "M_Precast-Rectangular Column with Corbels" column into project.
    Hide some of the corbels.
    Join column with floor (or attach top and etc).
    Corbels reappear without possibility to hide them again.
    Any ideas?
    ____________________________________________
    If you find my post useful give me Kudos. Thank you!
    If my post solved your problem, accept it as a solution.
    Please use plain text.
    Product Support
    Re: Hidden corbels of precast column appear unwanted
    02-11-2013 01:12 PM in reply to: Priitl220
    This is known behavior that the development team is currently investigating; the visibility settings are lost when the column is joined to anything. Once the settings are lost they cannot be undone - a new column has to be placed. In the meantime, you may want to try to avoid actually joining it or try creating separate families for each representation.
    I am sorry for the trouble that this causes to your workflow. Please let us know if there is anything we can do to help.
    Katie Langan
    Revit Support Specialist
    Revit Clinic
    Valued Contributor
    02-11-2013 10:24 PM in reply to: kathryn.langan
     I reported it two versions back (RST 2011) and still the answer is the same...
    Product Support
    02-12-2013 04:39 AM in reply to: Priitl220
    Yes, this issue is not new to 2013. Unfortunately it has proven to be complex to address and the development team hasn't been able to resolve it yet. I apologize as I realize this certainly isn't ideal but I do assure you they are working to address it. I am very sorry in the meantime for having to work around it.
    Katie Langan
    Revit Clinic
