• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Structure
    Distinguished Contributor
    Finding center of gravity
    1664 Views, 8 Replies
    02-16-2011 12:45 PM
    In AutoCAD when I needed to find the center of gravity for a shape I would create a region of the shape and use the mass properties to find the C.G.  is there any way to find the center of gravity for a shape in Revit?
    Please use plain text.
    Valued Contributor
    Re: Finding center of gravity
    02-16-2011 07:57 PM in reply to: haydenwse
    I belive there is no direct solution for calculating center of gravity in Revit, Though I always export my element as geometry or AutoCAD Architectural objects from Revit and then find the C.G. in AutoCAD Architecture.
    Raghavendra Bhat
    rnbhat1@gmail.com
    02-16-2011 08:03 PM in reply to: rnbhat
    That is what I thought.  I find it completely ridiculous that this program cannot give C.G.  I work with precast concrete and have to find the CG to determine how to pick up the pieces.  I don't believe that it is not possible for Revit to output this info.  The programmers just don't think that it is important.
    I for one could really use this feature.
    Active Contributor
    raghavendrabhat6624
    02-16-2011 09:51 PM in reply to: haydenwse
    Autodesk....Any Answers?
    02-22-2011 08:26 AM in reply to: raghavendrabhat6624
    Does anyone have any ideas for this issue?
    02-22-2011 10:01 AM in reply to: haydenwse
    Guess there might be a market for an Revit add-in for the precast detailers. :smileyhappy:
    Post the question to the http://thebuildingcoder.typepad.com/blog/ and in the Revit programming forums.
    Who knows, you might get lucky.
    M.
    Member
    floydwaldrop2092
    01-18-2012 01:34 PM in reply to: haydenwse
    i would be interested in knowing if you ever came up with a solution.  I would like to find the CG for something with two materials such as a precast stair tower box with a flight of steel stairs on one side.  sure revit structure does know where the center of gravity is.
    01-18-2012 02:07 PM in reply to: haydenwse
    Never did find a Revit solution.  I have been exporting the product to dwg file and use autocrat to find E.G..  It is about all that I use autocad for any more.
    I still can't believed that autocad can do this and Revit can't.
    Member
    floydwaldrop2092
    01-18-2012 02:45 PM in reply to: haydenwse
    we need more precasters speaking out.
