• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Structure
    Active Contributor
    sorgjee
    Export load combination to robot
    250 Views, 3 Replies
    01-16-2013 05:20 AM
    I'm attempting to implement loads, cases and combinations in revit for exporting a model to robot. I am able to get cases, loads and combinations names to export. The combinations do not have any cases or partial factor included in them though. How do I get revit to export these combinations correctly? (RST and RSA both version 2012.)
    Revit definition:
    Robot result:
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Export load combination to robot
    01-18-2013 01:50 AM in reply to: sorgjee
    This just should be done (see the attached picture). Could you send the Revit model so that I could check this?
    Artur Kosakowski
    Support Specialist
    Product Support
    Active Contributor
    sorgjee
    01-18-2013 02:21 AM in reply to: Artur.Kosakowski
    Hi Artur,
    I've tried to get it to move back and forth several times now, and it looks like it will only transfer if the whole model is export from Revit to Robot, not when doing a smaller selection of the structure.
    Product Support
    Artur.Kosakowski
    01-18-2013 02:59 AM in reply to: sorgjee
    This is enabled in v.2013 of the link.
    Artur Kosakowski
    Support Specialist
    Product Support
