• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Structure
    New Member
    Error message while using Extensions Revit 2013
    334 Views, 3 Replies
    11-22-2012 02:34 AM
    When I use revit extensions civil structures - Roads and terrain I get the following error:
    Extension encoutered a problem.
    The error occured on: AREX
     - Create method exception.
    Assembly name: DBridgeRoad: Object reference not set to an instance of an object.; StackTrace:    at REX.Bridges.Common. ...
    How do I solve this problem?
    Please use plain text.
    New Member
    Re: Error message while using Extensions Revit 2013
    02-17-2013 09:02 PM in reply to: MaartenBroersen
    Hello Maarten
    did you ever get a reply to your query, we're running the bridge extension here too and getting the same or a very similar error?
    Regards
    Neil
    New Member
    02-17-2013 10:17 PM in reply to: Sterneo
    Hello Neil, No. Unfortunately I have no response received. Therefore, I have the error sent to Autodesk in end December, but still waiting for reply. Regards, Maarten
    New Member
    02-18-2013 03:29 PM in reply to: MaartenBroersen
    Hi Maarten
    thanks for the reply, looks like this will take a while to fix??
