• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Structure
    Member
    Accepted Solution
    Cutting Similar sections on multiple locations
    258 Views, 2 Replies
    10-08-2012 03:47 PM
    New on Revit so hope my question is understandable.
    What is the best procedures to callout a section in multiple locations without creating multiple views?
    And/or using the same detail reference on different locations of the building?
    I have seen construction documents from others, where it appears this is achievable.  But I have not figured out a way to do this.  Hope some of you can help!
    EJ
    Please use plain text.
    Active Contributor
    Re: Cutting Similar sections on multiple locations
    10-09-2012 01:48 AM in reply to: RCSE_EJ
    Use referenced details.
    See attached image
    Regards, Jordi
    Member
    11-09-2012 10:30 AM in reply to: 5kings
    Thanks Jordi. Thats exactly what i did. I sorta figured it out right after i had posted the question. Thanks.
