Curved Beams
Curved Beams
Curved Beams
Hello All
I need some help as I have never done this before.
I  was wondering if you someone could tell me how to create a curved beam in either section or elevation. I was reading someone created one along a path but I don't know how to do that. I am using RST 2012. I am hoping that someone can guide me in the right direction. The architect has is shown on their drawings but this all new territory to me.
All help and suggestions welcome.
Regards
Kevin
Joe.Charpentier
Start the beam tool. In the ribbon (close to the right), there is a box with a bunch of different lines called the "Draw Gallery".
Note that the default is a straight line.
Chose one of the curves, and start sketching.
To create a vertically curved beam, switch to an elevation or section view, and do the same.
Joe
DRamirez
If the architect already has them in their model, and it is linked into your model.  Couldn't you try Copy-monitor?  Or you can copy and paste to same place.
Hi, the first time and several times after that, the arc option in the draw gallery would not be available for some reason. after kicking my computer and work on something else for a while. it seemed to become available and was able to draw the beam on a arc. (mental note: make sure you have a reference plan to draw on)
Thanks Joe
Kevin
DRamirezSSA
That thought never occured to me. Even though I have already drawn the framing, I am going go back and give the copy/monitor option a try. thanks.
Regards
Kevin
DRamirez
Giving it some further thought, I am not certain if you can copy-monitor them in.  But you can copy-paste for sure, when you select the link tab through to get the beam(s) you want and past to same place.  There are only certain items you can bring in with copy-monitor feature
Hello everybody,
When i transfer my model from RS to RSAP, my curve beams are divided too small, is there any way to change the division? Please show me!
