Message 1 of 13
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This situation comes up on many of our projects. We have a braced frame located on the exterior of a building. The beam at the floor is offset from the center of the grid so that the beam flange doesn't extend past the exterior of the building. The columns that are part of the frame must be hidden in the wall below and do not line up with the center of the beam. The braces that get drawn only attach to the centerlines of the beam and column, thus they stick out of the wall. This is driving us nuts. There has to be a way to model this correctly. I can use the analytical tools to get the analytical model to work perfect.
I have a model that is 1.8 mb but can't attach it here.
