• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Structure
    Member
    mshang
    Assign Rebar for 3D View as View as Solid for Rebar within a model group
    195 Views, 3 Replies
    11-19-2012 11:32 PM
    Hi All,
    I have rebar placed within a model group.
    This group is then copied about 1000 times.
    I want to change the View as Solid setting for a 3D view without having to edit each group individually as this setting does not propagate to all other instances of the group in the model.
    ie if it set in the group then this group is copied, the new group has it unchecked.
    Hope that makes sense and hope someone can help.
    Marty...
    Please use plain text.
    Product Support
    jad.dellel
    Re: Assign Rebar for 3D View as View as Solid for Rebar within a model group
    01-07-2013 10:46 AM in reply to: mshang
    Hello Marty,
    Sorry for the delay, we created a case for you (case 07831260).
    I will send you an email for more details.
    Jad DELLEL
    Structural Engineering Product Support Autodesk, Inc.
    Valued Contributor
    01-07-2013 11:29 AM in reply to: jad.dellel
    Jad,
    Where do you guys publish solutions to specific cases?  I am interested in knowing the outcome of this issue.
    Product Support
    jad.dellel
    01-07-2013 11:38 AM in reply to: kirbybeegles4894
    In such case, we need more information from the customer.
    After, if a solution exists, we will share it in the forum.
    Jad DELLEL
