• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Structure
    Distinguished Contributor
    2013: Underlay link causing link to turn halftone.
    350 Views, 2 Replies
    07-20-2012 08:42 AM
    Why?
    I am working in a project that we upgraded from 2012 to 2013. In 2012, I had filters set up to show a piece of the Architectural link (a generic model; elevated seating slabs) would show as solid linework in my sections.
    Basically,
    • I left the overall Halftone of the link as unchecked. But set the link as an underlay.
    • Then, I set the link to Custom and I took every model element in the Architectural link except Generic Models and set them to halftone.
    • Then created filters to grab the specific generic models I wanted on and turned all the others off.
    • Then I created a view template that I could re-use on other, similar sections.
    In 2013, the Underlay feature seems to have an additional "feature" that is unwanted. When I set the Architectural link to Underlay, it does send the file under my structural model, but it also makes the underlay HALFTONE! So, I cannot get that piece of generic model to show solid. Why have the additional Halftone checkbox if the Underlay is going to do that anyway?
    I also tried with a new 2013 project template, linking the same Architectural model and cutting the same section. When I set the link to underlay, it turns halftone, too! Also, tried changing from Structural to Coordination with no change.
    Leanne Zaras, CDT, LEED AP
    AutoCAD 2010 Certified Professional
    Revit Architecture 2012 Certified Professional
    Please use plain text.
    Re: 2013: Underlay link causing link to turn halftone.
    07-23-2012 08:38 AM in reply to: lzaras1
    UPDATE:
    To turn off automatic Halftoning of the Underlay feature, go to
    Manage Tab > Settings Panel > Additional Settings pulldown > Halftone / Underlay dialog box
    and uncheck the "Apply Halftone" checkbox.
    Employee
    Joe.Charpentier
    07-23-2012 09:08 AM in reply to: lzaras1
    Thanks for posting the solution, Leanne.
