• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Valued Contributor
    sloped ductwork tag
    214 Views, 5 Replies
    02-14-2013 07:58 AM
    So I have a lot of duct that is sloped for offset purposes. Is there away to write a tag that will say what the slope angle is for these ducts? If so how do you do it? Thanks!
    Please use plain text.
    Re: sloped ductwork tag
    02-14-2013 08:31 AM in reply to: michaelmead
    A Spot Slope will work for that. I'm not sure about incorporating it into a duct tag though.
    Valued Contributor
    02-14-2013 08:51 AM in reply to: abulla
    What is a spot slope?
    Valued Contributor
    02-14-2013 09:19 AM in reply to: michaelmead
    I need something that can be taged.
    02-14-2013 09:35 AM in reply to: michaelmead
    On the Annotate tab, there's a Spot Slope button that you can use to tag the slope of pretty much anything, including duct.
    Valued Contributor
    02-14-2013 10:27 AM in reply to: abulla
    THANKS!
