• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    New Member
    show pipe not floor
    166 Views, 4 Replies
    10-03-2012 11:31 AM
    Hello All,
    I would like to know if there is a way to show underfloor piping without showing anything else from the floor below.
    For example: Create a second floor sheet showing second floor plumbing fixtures and only show the sanitary lines serving the second floor that is located in the first floor ceiling without showing other items from the first floor.
    Murph
    Please use plain text.
    Valued Mentor
    dennis
    Re: show pipe not floor
    10-03-2012 11:35 AM in reply to: mmcmurphy
    1) You could try using the Plan Region, but it is rather buggy with MEP.
    -or-
    2) Set the ViewRange/Bottom and ViewDepth to the same value to include the Sanitary pipe below the floor you are on, then TAB select the objects to hide, right-click HideInView.
    New Member
    10-03-2012 11:42 AM in reply to: dennis
    This is a good idea however it will take for ever to tab select hide in view by element, (if I do by catagory all my second floor walls hide also), I was wondering if there was a faster way, can you explain plan region to me? -- * Michael McMurphy * *"No problem can be solved from the same level of consciousness that created it." **-Albert Einstein-*
    Distinguished Contributor
    10-04-2012 09:24 AM in reply to: mmcmurphy
    Look through past messages on showing 2 views on a plot sheet.  Basic intent is to show the upper plan with the architectural walls and piping on and turning the architectural link off in the lower plan (thus turning the walls off on the floor below) and only showing the piping.
    Active Contributor
    sforsberg215
    10-04-2012 10:08 AM in reply to: mmcmurphy
    sounds like you should create (2) two seperate views w/ the VG set the way in each the way you want. Then drag them onto the sheet that you want.
    I seperate domestic water from sanitary piping this way.
