• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Active Contributor
    Accepted Solution
    sanitary tees
    273 Views, 3 Replies
    10-09-2012 08:48 AM
    If I have a sanitary tee in a run, and I click on the + to make it a double sanitary tee, it never works.I get this error: "The converted fitting was not defined in the routing preference. Please assign one on the connected curve types."
    I can insert a doulbe sanitary tee in the main manually, and then reconnect the other branch lines.
    Anyone know an answer as to how to make it work in the first place?
    genem@... (NNTP handle: genemarz)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 10 years
    as genemarz
    Please use plain text.
    Valued Mentor
    dennis
    Re: sanitary tees
    10-09-2012 09:16 AM in reply to: genem
    The double-sanitary fitting needs to be defined as a cross in the routing preferences of the pipe type.
    Active Contributor
    Re: sanitary tees
    10-09-2012 09:20 AM in reply to: dennis
    I think it was already?
    as genemarz
    Distinguished Mentor
    asommer
    Re: sanitary tees
    10-09-2012 10:48 AM in reply to: genem
    Go to the "Type" Properties of the pipe type you are using.  under the "Fitting" parameters, you can select what type of "Cross" to use.  select your double sanitary tee next to the Cross type.  You might have to delete the tee and re-create the connection for it to recognize the change.
