Autodesk Revit MEP
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
sanitary tees
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If I have a sanitary tee in a run, and I click on the + to make it a double sanitary tee, it never works.I get this error: "The converted fitting was not defined in the routing preference. Please assign one on the connected curve types."
I can insert a doulbe sanitary tee in the main manually, and then reconnect the other branch lines.
Anyone know an answer as to how to make it work in the first place?
You may recognize me from the
hundreds of previous newsreader posts
I've made over the last 10 years
as genemarz
Re: sanitary tees
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The double-sanitary fitting needs to be defined as a cross in the routing preferences of the pipe type.
Re: sanitary tees
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think it was already?
as genemarz
Re: sanitary tees
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Go to the "Type" Properties of the pipe type you are using. under the "Fitting" parameters, you can select what type of "Cross" to use. select your double sanitary tee next to the Cross type. You might have to delete the tee and re-create the connection for it to recognize the change.
