• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Valued Mentor
    dennis
    Accepted Solution
    repositioning msg- RMEP 2013 SP2
    147 Views, 1 Replies
    12-17-2012 08:09 AM
    We have a couple projects that when the arch client links in our MEP file, they continuously get a reposition msg that the MEP has been moved from <current>.  We can select any option, but it keeps coming back.  This project NEVER had shared coordinates, and only linked in via Origin-Origin.
    We would prefer to select the third option: Disable Shared Parameters, but it doesn't take when we select it and keeps popping back up.
    Any suggestions?
    Please use plain text.
    Product Support
    Re: repositioning msg- RMEP 2013 SP2
    12-18-2012 03:50 PM in reply to: dennis
    The following document has information on this issue:
    Location Position Changed dialog when saving in Revit
    http://usa.autodesk.com/getdoc/id=TS14334953
    If after clicking "Disable shared positioning", closing the project, and then reopening it (as described in the link above), the message returns, try selecting the linked MEP project, open the Shared Location dialog, select Do not share location of selected instance and click OK.
    Lance Coffey
    Support Specialist
    Product Support
    Autodesk, Inc.
