• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Accepted Solution
    *plumbing, *fire, etc identity data?
    242 Views, 3 Replies
    10-26-2012 08:47 AM
    What are the *HVAC, *Plumbing, and *Fire Protection check boxes for in pipe properties?  I noticed that there are filters for these parameters.  The duplicate mark error is driving me crazy.  Can these parameters be used in some way to keep plumbing pipes from constantly (and I mean every pipe) taking the same Mark as HVAC pipes?  Our plumbing is drawn on a separate workset for visibility control.  Is this why the duplicate mark warning keeps showing?
    Please use plain text.
    *Expert Elite*
    Re: *plumbing, *fire, etc identity data?
    10-26-2012 09:05 AM in reply to: DanetteErnst2982
    Those Parameters are not default Revit Parameters - they must have been added as Project Parameters. Anyhow, these would not be the cause of the duplicate Mark values. Project Worksharing is more likely the cause. Whenever you create a new element (regardless of Category or Type), the elements is assigned the next highest number in the Project.
    Say two users create Local files for a Project, in which the highest Mark value is 7. Now User #1 creates a Pipe, so Revit assigns it a Mark value of 8. Now User #2 creates a Pipe before User #1 sychronizes. His Pipe will be assigned the next Mark value of 8, since it is yet 'unaware' that User #1 already used that Mark value.
    Corey D.        ADSK_Logo_EE_2013.png    AutoCAD user Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    10-26-2012 12:34 PM in reply to: CADastrophe
    Oh CADastrophe, you are right as always.  The parameters are in our company template.  The parameters and filters were set up to control visibility of equipment and pipe before systems were developed to the point that they are in 2013.  Additionally, I was sure that I was the only person modeling pipe today, but not so.  Therefore, the duplicate mark warnings also make sense.
    *Expert Elite*
    10-26-2012 12:46 PM in reply to: DanetteErnst2982
    I just thought of a rudimentary method that might help you avoid this error. Do this every time you Synchronize with Central (or create a new Local file) to the very first element you create afterwards: Manually change the Mark Value to add 1000 or some other high number to it. That way, your Local file will start counting from that number whilst the other user continues from the original count.
    The above would *theoretically* work very well with two users (only one of them adds the 1000 to Mark), but if you have more than two, then the error will probably still crop up unless other users take similar action. Also, note that the above is unnecessary if the users aren't working simultaneously.
    Edit: I'm not entirely correct: The Mark Value is actually counted separately between different Categories of Elements, contrary to my statement above:
    "(regardless of Category or Type)"
    In light of this, the above might not work as well as I hoped...
