Autodesk Revit MEP
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
non square crop regions
Options
- Highlight
- Email to a Friend
130 Views, 1 Replies
03-07-2013 06:29 AM
I am trying to do an enlarged plan of an apartment and would like to crop out a section of an adjoining apartment that falls inside the crop box. Is there a way to do a non rectangular crop region?
Re: non square crop regions
Options
- Highlight
- Email to a Friend
03-07-2013 06:39 AM in reply to:
mmcglone
Not at this time. That's an item that's on every Revit wish list, I think.
If you want to 'block out' an area of a View, you can create a Masking Region, and that should do the trick. Be sure to place the boundary lines to "<Invisible Lines>" while sketching the boundary region.
Note: This method will fail if your View is set to Visual Style: Wireframe.
Corey D.
⁞|⁞ Please use the
.Accept as Solution and
Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
⁞|⁞ Please use the
