• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Active Member
    septembersmile
    Accepted Solution
    filter & control the Archi Revit Reference catagoies
    158 Views, 2 Replies
    11-25-2012 09:13 PM
    Hi. Everyboday .. Good day to u :smileyhappy:
    Please help me to give advice how to filter & control the Archi Revit Reference catagoies ..(for example .. I want to be off the Demolish Categories .)
    Many Thanks ,
    Smile
    Please use plain text.
    *Expert Elite*
    Re: filter & control the Archi Revit Reference catagoies
    11-26-2012 05:16 AM in reply to: septembersmile
    In order to control the appearance and visibility of the Categories belonging to a linked model separate from your model's settings, go to Visibility/Graphics Overrides » Revit Links. Under Display Settings for the link(s), click on the button which will read either "By Host View" or "Custom". This will take you to another dialog titled "RVT Link Display Settings" which appears just like V/G. In the first tab, set the top option to "Custom" and then you can go to the other tabs (set the pull-down at the top to read "Custom") and set the visibility as desired.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Active Member
    septembersmile
    11-26-2012 06:29 AM in reply to: CADastrophe
    Thank You Very Much for your Reply ::smileyhappy:
