Autodesk Revit MEP
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Which family template should I use to create supports or hangers for pipes?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi everyone,
I'm new with Revit and I need to create a family of supports or hangers.
Which template should I use if I want to place my supports on my pipes and then adjust the parameters to make it fit on steel beams?
I tried to use Plumbing Fixtures, but when I inserted it in my project, i couldn't place them the way I wanted.
William Comtois
P.S. : I found a topic on the subject, but it didn't really help me out - http://forums.autodesk.com/t5/Autodesk-Revit-MEP/Q
Re: Which family template should I use to create supports or hangers for pipes?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We have used pipe accessories and that seem to work well.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
tjbeecher wrote:We have used pipe accessories and that seem to work well.
Am I supose to find this .RFT in the basic templates of Revit MEP?
Otherwise, can you send it to me please? ![]()
William Comtois
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am using 2013. I had to create it with a generic model template then change it before I started modeling the hangers.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ok, I am using 2013 too, but when you say that you had to change it before you started modeling the hangers, what did you change?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Attached are to pictures. one is showing the family categories and paramteres buttonto click on. Once the box comes up scroll down to the pipe accessoeris one.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Well, and do I need to change any parameters or just change the categorie to "pipe accessories"?
I tried to just change the categorie, i modeled something simple (A cylinder) and I tried to insert it in my project. Nothing happened... My cylinder seems not to be added in my project...
Some ideas?
William Comtois
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi you need to be using a Generic Model Template found in (C:\ProgramData\Autodesk\RME 2011\Metric Templates)
Make sure to add Pipe Connectors one in and one out. (See image attached)
For family Category & Parameters make you’re to Part Type is set at Breaks Into (See image attached)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for your answer,
I tried to create a simple cylinder and to put it down on my piping system the way you told me to do it, but when i do so, some transitions appear on both sides of my cylinder (see image attached)
Is there anything to do to avoid those transitions?
Will
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi mate
You need to make sure that your radius on your pipe connector is the same size as the pipe in your model. See image attached.
