• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    CADArmor
    Volume of Mechanical Ducts
    299 Views, 2 Replies
    10-03-2012 10:33 PM
    Is there a way other than manual calculations to calculate the volume of mechanical ducts in REVIT MEP 2012?
    Picture attached shows a duct system highlighted in yellow. I need to calculate the entire volume of that duct system. Can someone please help?
    Please use plain text.
    Re: Volume of Mechanical Ducts
    10-08-2012 07:53 AM in reply to: CADArmor
    I would image that you could create a Duct Schedule sorted by their individual size Parameters (i.e. Height, Length, Diameter) and create a Calculated Value to total up the volume. In fact, I believe that there is already an "Area" parameter that may of some use. For each type of Duct (Rectangular, Round, Oval) you would need a separate Calculated Value or perhaps a Separate Schedule to keep it cleaner. I don't think that this would account for Duct Fittings, though.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Distinguished Mentor
    asommer
    10-09-2012 11:36 AM in reply to: CADArmor
    The area that Revit gives in the schedule is Sheetmetal area.  It's kinda odd that volume isn't here for ducts.  You would have to do Height * Width * Length for Rect duct, and the other thing for Round.  You can sort the schedule by system name, set up the calculated values to calc the Volume of each duct, and set the "Volume" to calculate totals in the formatting tab.  It is a lot to do, but I had done this to calculate total duct weight on a project.
    Good Luck!
