View Range
View Range
View Range
Is it possible in the View Range to see from floor to ceiling of an attached Architectural model while only seeing smaller view range of plumbing pipework that passes through a slab?
My issue is that is that if i set the view range to only see from the top of level 1 slab to the underside of the slab i then can't see sanitary fixtures (toilets, handbasins, etc.) on the architectural model.
Take a look at VG-->RVT Links-->click the (+) use the child (parent doesn't work)-->Not Overridden-->Override display setting for this instance-->By Linked View-->Select a linked view that will work.
This is like a snapshot for a background.
You will have to change it to custom rather than By linked view to manipulate the model even further.
Like turn off the Arch's annotations.
Just play around with this and see if you can get the results you want.
Thanks that helped a lot
