Autodesk Revit MEP
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Vic fittings always loads 45 deg elbow
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi we are using revit mep rel. 2012.
i downloaded the grooved revit fittings from Victaulic site.
added them to family,
can see all except when i try to draw a lenght of pipe and change directions,
revit adds a 45 deg. elbow when i want a 90 deg.
HAS ANYONE HAD THIS PROBLEM?
Re: Vic fittings always loads 45 deg elbow
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Could you post one of the uncooperative families files as well as the corresponding catalog .txt file (if there is one)?
⁞|⁞ Please use the
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
here is the file no txt file
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
A believe this fitting requires a lookup table named, "Victaulic-IPS-Elbow No 10-13.csv". This file should have been downloaded along with the .rfa file.
⁞|⁞ Please use the
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes i found these files, do i have to tell Revit where to look?
if so how?
thanks
C:\ProgramData\Autodesk\RME 2012\Libraries\US Imperial\Vic fitings\autodesk-revit-mep\ips\Autodesk-Revit-MEP-
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You need to place the csv into the lookup table directory which should be
C:\ProgramData\Autodesk\RME 2012\Lookup Tables\Pipe
They should then work correctly.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you! works great!
