• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Active Contributor
    sforsberg215
    Under floor piping Revit MEP 2012
    335 Views, 2 Replies
    10-25-2011 06:51 AM
    Hi
    in 2011, all my underfloor piping showed up dashed and halftone. in 2012, all my underfloor piping shows up solid and dark. What is the setting and where is it to make the below ground piping dashed?
    Please use plain text.
    Valued Mentor
    julianjameson8403
    Re: Under floor piping Revit MEP 2012
    10-25-2011 08:16 AM in reply to: sforsberg215
    Under the manage tab>additional settings - check the linetype <beyond>
    If my reply answers your query, please use the Accept as Solution.
    Please give Kudos as appropriate to enhance the value of these forums.
    Thank you!
    Distinguished Mentor
    10-25-2011 08:14 PM in reply to: sforsberg215
    This works only if your view range
    Is set to bottom =0 and your view depth its below that.
    “Anything worth doing is worth doing poorly, until you can learn to do it well.”
